SAML SSO - Lineworks as SP
silverstone
2018.06.04既読 3422
We need to enable LineWorks(as SP) SAML SSO with our Identity Provider. Can we have the configuration steps for it?
    silverstone 投稿者
    We are getting certification time is incorrect alert when trying SAML SSO with our IdP.
    2018.06.04
    Restriction on "NotBefore" in your assertion seems to be too severe.
    The value may be set to SAML assertion's created time.
    As long as the same NTP server is not referenced,
    there often are some time synchronization deviations between the servers.
    Our server got your SAML assertion about 20 secons before "NotBefore" in the assertion.
    Could you mind relaxing the restriction on "NotBefore" a little?
    Thanks.​
    2018.06.05
    silverstone 投稿者
    Thank you for your response. Actual error message can be detailed. Instead of certification time is incorrect.
    2018.06.05
前の投稿LINEWORKSデベロッパーコンソールからoffした場合の挙動について
次の投稿SAML2.0 SSO連携について
