Bot messages are not delivered to end user at a same time
シャーバビック
2021.08.31既読 3245
I am using LineWorks Message Bot api to notify our end user, but getting complain from users that they are getting messages not in a same time.
Example: from my system I send notification to User A, B and C
now users are getting messages like:
User A: after 1 minute
User B: after 5 minute
User C: after 25 minutes
We checked at our end is there any calling delayed at our end but we are not found that. We called API for all three users at a same time.
Now we need help from your end:
- Is there any way from where we can also check when message processed and send to end user?
- Is there any screen or API available for message bot?
- Is there any chance of delayed when called LINEWORKS api?
- Is there any limitation like in 1 hour or 1 days this much calls are allowed for Bot message?
Please let me know if you have any other question or queries on above points.
Thanks in advance
    Regarding message processing, API Request is processed as soon as it arrives at the server and reflected in the talk.
    I confirmed it in this verification environment, but it is immediately reflected in the talk.
    There is a possibility of temporary symptoms depending on your environment, so please check again after a while. We apologize for the inconvenience.
    There are three request restrictions as follows.
    ① Exceeding the number of API calls that can be executed within a certain time (60 seconds) (Rate Limit)
    ② Exceeding the number of simultaneous connections
    ③ Exceeding the quota per day (maximum number of times limit)
    Please refer to the following page for details.
    https://developers.worksmobile.com/jp/document/3002003?lang=en
    https://developers.worksmobile.com/jp/document/1005008?lang=en
    メッセージの処理ですが、API Request がサーバに届いたのちすぐに処理されトークに反映されます。
    こちらの検証環境でも確認いたしましたが、すぐにトークに反映されております。
    ご利用の環境による一時的な症状の可能性もございますので、お手数をおかけしますが時間をおいてから再度ご確認ください。
    リクエスト制限には下記の3つがあります。
    ① 一定時間内(60秒)に実行可能な API 呼び出し回数超過(Rate Limit)
    ② 同時接続数超過
    ③ 一日あたりのクォータ(最大回数の制限)超過
    詳細につきましては下記のページをご参考ください。
    2021.08.31
前の投稿コンテンツアップロードの4001、Invalid Authについて
次の投稿リクエスト制限(Rate Limit)の単位に関して
