Lineworks chatbot
Randy
2019.11.21既読 3425
Hi,
The auth token that we've received is expiring immediately even though the expiration of the token is 24 hours.
We just followed the documentation/procedure on Server Token (ID Registration Style).
Thank you.
Here is the attached screenshot of the response
    Have you issued a token with the same authentication key after issuing a token?
    Even if the access_token is still valid, if the token is reissued, the previous token becomes invalid.
    2019.11.26
    Randy 投稿者
    Thank you. I have solved it. Does it happen in service token too?
    2019.11.26
    Authorization Code for issuing Service API Access Token is valid only once.
    Token cannot be reissued with the same Authorization Code.
    2019.11.26
前の投稿SSO連携ログイン方式の場合アカウント作成した際ユーザーへ招待メールが飛ばない(解決済み)
次の投稿SSO導入後のモバイル版アプリ利用
