Auth errors: Current time is earlier than NotBefore
シャーバビック
2018.04.04既読 3586
Hi There,
We are working on line works SSO where we allow our users to get into our system from line works credentials. It was working fine on our staging instance but recently we are having an issue. We are getting below error consistently now.
Auth errors: Current time is earlier than NotBefore.
Some time we found it working also but most of the time we are getting this error only. Our staging instance is on Amazon EC-2 in Oregon region. Googling on the issue we found there might be some issue with timezone which can be rectified by IDP end.
More details :https://developer.uservoice.com/docs/single-sign-on/single-sign-on-with-saml/
Can you please confirm?
    That error also happens when server time synchronization is not working correctly.​​
    What was the difference between "NotBefore" value in response and server's time?​
    Thanks.
    2018.04.04
    シャーバビック 投稿者
    It looks like the time is same.. Copied it from Log.
    saml: Auth errors: Current time is earlier than NotBefore condition (2018/04/03 04:34 < 2018/04/03 04:34)
    2018.04.04
    If you want compare correct time value, you should check the epoch time.
    What is the epoch ​time of "2018/04/03 04:34" ?
    Thanks.​
    2018.04.06
前の投稿SSOしている場合のLINEWORKSメールのIMAP取込みについて
次の投稿LINE WORKSのSAML認証の仕様について
