Turning off SSO
TandinganWillie Loyd
2018.01.29既読 2349
I would like to switch off from using OAuth2 but even though the developer console page shows the option as Off after saving, logging in still goes through SSO.
Is turning off SSO supported?
    We support turning off SSO.
    You can turn off SSO through Developer Console, as you tried.
    Does the problem still occur?
    Could you tell us your using domain of LW?
    2018.01.31
    TandinganWillie Loyd 投稿者
    I just checked again. It seems to be fine now. Thanks!
    2018.02.01
前の投稿Liteプランについて
次の投稿Sandbox support
