VBAでラインワークスのコンテンツアップロードを行いたい
K’
2019.08.29既読 9972
参考URL
https://developers.worksmobile.com/jp/document/1005025?lang=ja
VBAでラインワークスのコンテンツアップロードを行いたいのですが
下記エラーが表示されます。
実行時エラー '-2146697208(800c0008)'
指定されたリソースのダウンロードに失敗しました。
以下、コードです。
Function CreateNomarlParameter(fct, fctm)
s = ""
s = s & fct & fctm & vbCrLf
s = s & vbCrLf
CreateNomarlParameter = s
End Function
Function CreateFileParmaterPrefix(fname, fvalue, fct)
s = ""
s = s & strBoundary & vbCrLf
s = s & "Content-Disposition: form-data; name=""" & fname & """; filename=""" & fvalue & """" & vbCrLf
s = s & "Content-Type: " & fct & vbCrLf
CreateFileParmaterPrefix = s
End Function
Private Function ChangeStreamType(stream, adType)
Dim p As Long
p = stream.Position
stream.Position = 0
stream.Type = adType
If adType = adTypeText Then
stream.Charset = "UTF-8"
End If
stream.Position = p
Set ChangeStreamType = stream
End Function
Public Function ChangeChr(strXML) As Byte()
Dim objSTREAM As Object
On Error Resume Next
Set objSTREAM = CreateObject("ADODB.Stream")
With objSTREAM
.Open
.Type = adTypeText
.Charset = "UTF-8"
.WriteText strXML
.Position = 0
.Type = adTypeBinary
.Position = 0
ChangeChr = .Read()
End With
objSTREAM.Close: Set objSTREAM = Nothing
End Function
Public Function KickWebApiOfDATA(ByVal request As String, ByVal url As String, Optional ByVal param As String) As Object
Const adTypeBinary = 1
Const adTypeText = 2
Dim json
json = ConvertToJson(param)
Dim strBoundary: strBoundary = "--" & DateDiff("s", "1970/1/1 0:00:00", DateAdd("h", -9, Now))
Dim endBoundary: endBoundary = vbCrLf & "--" & strBoundary & "--" & vbCrLf
Dim StreamB
Dim StreamS
StreamS = ""
Set stream = CreateObject("ADODB.Stream")
stream.Open
stream.Type = adTypeBinary
stream.LoadFromFile param
StreamB = stream.Read
stream.Close
stream.Type = adTypeText
stream.Open
ChangeStreamType stream, adTypeText
StreamS = "--" & strBoundary
StreamS = StreamS & CreateFileParmaterPrefix("resourceName", Dir(param), "application/octet-stream")
StreamS = StreamS & CreateNomarlParameter("Content-Transfer-Encoding: ", "binary")
stream.WriteText StreamS
ChangeStreamType stream, adTypeBinary
stream.Write StreamB
stream.WriteText endBoundary
stream.Position = 0
formdata = stream.Read
Dim http As Object
Set http = CreateObject("Msxml2.XMLHTTP")
With http
.Open request, url, False
.setRequestHeader "consumerKey", Sheet2.Cells(2, 3)
.setRequestHeader "authorization", "Bearer " & Sheet2.Cells(3, 3)
.setRequestHeader "x-works-apiid", Sheet2.Cells(6, 3)
.setRequestHeader "Cache-Control", "no-cache"
.setRequestHeader "Content-Length", stream.Size
.setRequestHeader "Content-Type", "multipart/form-data; boundary=""" & strBoundary & """" & vbCrLf
.Send formdata
If .ResponseText <> "" Then
Set KickWebApiOfJsonDATA = ParseJson(.ResponseText)
Debug.Print .ResponseText
End If
End With
Set http = Nothing
stream.Close
End Function
Sub OnClick_PostDATA()
Dim param As String
param = "C:\tools\QRtest.png"
Debug.Print JsonConverter.ConvertToJson(param, Whitespace:=2)
Call KickWebApiOfDATA("POST", "http://storage.worksmobile.com/openapi/message/upload.api", param)
End Sub
OnClick_PostDATA()を呼び出してラインワークスのコンテンツアップロードを行おうとしています。
なお、メッセージの送信はできるので
に関しては問題ないと思います。
    K’ 投稿者
    https://qiita.com/kunihiros/items/9816fa1860613b3b1a3a
    上記URLはNode.jsでのコンテンツアップロードコードですが
    実行してみたところ下記のエラーが発生しました。
    error start
    { Error: read ECONNRESET
       at TCP.onStreamRead (internal/stream_base_commons.js:111:27) errno: 'ECONNRESET', code: 'ECONNRESET', syscall: 'read' }
    2019.08.29
    こちらでは個別のコードに関するコメント、トラブルシューティングは控えさせていただきます。
    ご了承ください。
    2019.08.30
    K’ 投稿者
    下記エラーが表示されます。
    このエラーコードはどういう意味なのでしょうか?
    2019.08.30
    K’ 投稿者
    レスポンスが遅いので速くしてほしいです。
    2019.08.30
    Excel のエラーのようですので、エラー内容についてはマイクロソフト社にご確認いただけますでしょうか。
    このコミュニティは技術的な意見交換の場でサポートではないため、ベストエフォートでの対応となってしまいます。
    ご了承ください。
    2019.08.30
前の投稿Office365のカレンダーとLINEWORKSのカレンダーを連携したい
次の投稿トークBot APIのエラーについて
