利用規約見る
Lokesh
2019.11.08既読 4436
Hello Team,
Could you please help me, how can i get works id of User.
Thank you.
Lokesh 投稿者
2019.11.12
To check the latest login time, check the usage status from the security on the administrator screen.
2019.11.08
Lokesh 投稿者
In my web application, I need to show logged in user LineWorks id when he successfully logs in using LineWorks OAuth. How could I achieve it?
2019.11.08
https://developers.worksmobile.com/jp/document/1001070101?lang=en
The IDP should know the ExternalKey of the logged-in user, so Get a Member API can view user information with the ExternalKey.
https://developers.worksmobile.com/jp/document/100300507?lang=en
The email parameter is the login user's accountId.
2019.11.12
