The problem when requesting Auth API
zeno_492153
2023.06.13읽음 1716
Hi there. I met a problem when I following this instructions(https://developers.worksmobile.com/kr/docs/auth-jwt)
I tried to get a jwt token by posting this domain (https://auth.worksmobile.com/oauth2/v2.0/token') It always returned a reponse like this "
Error: write EPROTO 140727886667336:error:100000f7:SSL routines:OPENSSL_internal:WRONG_VERSION_NUMBER:../../../../src/third_party/boringssl/src/ssl/tls_record.cc:242:
", which seemed like a SSL problem. But I was sure that I follow the every single step of the document.
Could you help me with that? Thanks very much.
Best regards
    bsw2428
    저도 한번 확인해볼게요
    2023.06.15
이전 글API 2.0 여러 도메인에서 사용할 수 있는지 여부
다음 글API2.0 연동 사원 연동시 orgUnitId 해당값이 반드시 들어가야 하나요?
