SMTP 메일연동
choijinhwan
2021.12.02읽음 8015
그누보드를 이용하여 네이버웍스에 연동 하여 메일을 발송하려 합니다 .
ADMIN > 서비스 > 메일 > 송수신관리에서 SMTP 외부허용등을 설정하였습니다
그리고 프로그램에서 STMP 서버 연동 등을 작업 진행을 시행하였고
메일발송시 아래와 같이 메일 발송에러가 나타납니다
2021-12-02 07:20:30 SERVER -> CLIENT: 220 smtp.naver.com ESMTP u7fwZPC-T6qsUZI1XEhI9A - nsmtp 2021-12-02 07:20:30 CLIENT -> SERVER: EHLO imp.or.kr 2021-12-02 07:20:30 SERVER -> CLIENT: 250-smtp.naver.com Pleased to meet you 250-SIZE 20971520 250-8BITMIME 250-PIPELINING 250-AUTH PLAIN LOGIN 250 ENHANCEDSTATUSCODES 2021-12-02 07:20:30 CLIENT -> SERVER: AUTH LOGIN 2021-12-02 07:20:30 SERVER -> CLIENT: 334 VXNlcm5hbWU6 2021-12-02 07:20:30 CLIENT -> SERVER: c2VhMTIzMQ== 2021-12-02 07:20:30 SERVER -> CLIENT: 334 UGFzc3dvcmQ6 2021-12-02 07:20:30 CLIENT -> SERVER: Kndsc2doa3MxMDMw 2021-12-02 07:20:30 SERVER -> CLIENT: 235 2.7.0 Accepted u7fwZPC-T6qsUZI1XEhI9A - nsmtp 2021-12-02 07:20:30 CLIENT -> SERVER: MAIL FROM: 2021-12-02 07:20:30 SERVER -> CLIENT: 554 5.7.1 The sender address is unauthorized u7fwZPC-T6qsUZI1XEhI9A - nsmtp 2021-12-02 07:20:30 SMTP ERROR: MAIL FROM command failed: 554 5.7.1 The sender address is unauthorized u7fwZPC-T6qsUZI1XEhI9A - nsmtp 2021-12-02 07:20:30 The following From address failed: mail@imp.or.kr : MAIL FROM command failed,The sender address is unauthorized u7fwZPC-T6qsUZI1XEhI9A - nsmtp ,554,5.7.1SMTP server error: MAIL FROM command failed Detail: The sender address is unauthorized u7fwZPC-T6qsUZI1XEhI9A - nsmtp SMTP code: 554 Additional SMTP info: 5.7.1 2021-12-02 07:20:30 CLIENT -> SERVER: QUIT 2021-12-02 07:20:30 SERVER -> CLIENT: 221 2.0.0 Closing connection u7fwZPC-T6qsUZI1XEhI9A - nsmtp
이전 글FlexableTemplate에 File 전송
다음 글ID등록방식 토큰 발급 후 메세지 Bot API 사용시 401 Error 발생
